1 - 3 of 3 Posts
Waifu Deluxe
I have a Progress 24mm rear sway. Previous owner installed, didn't know it had spherical end links, and I already bought the hardrace OEM links.
Just curious what my options are here? If I need to run sphericals, or if I could run the Hardrace ones and if I do what are the effects of that?
Also the bar is rather loose when it's jacked up and I can easily move it side to side, I assume this is because of the bushings and not so much the end links? I have new bushings but curious if I'd even NEED to replace the end links? They are rather rusty, but I can still sort of twist my fingers on them and get the links to swivel a bit around the bolts holding the bar on and the bottom link to the car. If it's not seized up are they still good to go?
Thanks for any help!
I think you'll be ok with the Hardrace end links. Back when I was doing my end link research, I read several posts stating that OEM links will work with bars up to 25mm.
Not sure on whether or not you need to swap out the spherical ones yet though.
Waifu Deluxe
Thanks! I have a friend running another set in a 24mm swaybar, but wasn't sure how they'd impact on this one since this is the adjustable swaybar and I believe it has two mounting holes.
1 - 3 of 3 Posts
