1 - 14 of 14 Posts
What's up clubrsx! This has probably been covered before but will I see any significant gains going from z1 cams to 06-08 TSX cams? Will it be worth to switch over to these cams?
Thanks for your input!
From what i read 06 07 08 tsx cams doo add like 15 20 hp and keep the engine more reliable than an aftetmarket cam setup. Theres a dude w a 20 minute video talking about this and other stuff on youtube when i get off work ill link it. Im not the most knowledgeable but i think im going to do tsx cams after intake manifold and throttle body upgrades and im out of bolt ons to do
As far as why they keep it more reliable Idk he was saying something like k series is know for reliability and using tsx cams wont bring you away from that reliability like aftermarket cams would
Feel like im gonna get flamed if it soubds like idfk what im talking about its because i dont i just research shit and figure it out as i go..
Thanks for the input. I think the video you're talking about is the Evan's tuning k-series checklist. It's could be a good source since he's been in the industry tuning and has the experience and knowledge.
Discussion Starter #5
I haven't found Dyno comparisions between the two. Anyone out there can provide sheets? Any input/thoughts are appreciated.
i never believed what everybody said that z1 cams are the same as R cams. What can i tell you is A2 vs K2A2 Cams i did the swap and the car feels stronger.
Back from the dead...
06-08 TSX intake and exhaust cams a great add. The 04 TSX exhaust cam is the same as 06-08's.
K20z1 cams are extremely close to PRC cams, different part number, and very hard to claim that much difference. When compaired to 06 tsx cam, the lift is larger but the PRC/Z1 has better duration suiting top end better.
These are my findings from the Honda scene I know around here in southeast VA
15-20 wow!
So who else or where can I confirm this information ? I’m about to get a 72mm tb and ported rbc and I saw some 06 tsx cams for sell so I would like to know if I just need the cams or I need something else for can swap them on my k20z1 also should I swap both cams or just the exhaust one for the best gains ?thanks
05 Type S RH Reflash LSD
I don't think you need anything besides the cams for OEM swaps
This old thread seems to have good thoughts about it in this post: Camshafts From Honda....
Another thought: Tsx exhaust cam in a k20a2
And another: JDM ITR Cams VS 05-06 Cams
So basically it seems the consensus is, do the TSX 06+ exhaust cam, but if you have a K20A2, then go ahead and get the TSX intake cam, too. If you have a K20Z1, the TSX intake came wouldn't make much difference. However, there is a chance that the intake cam still doesn't help you. Our K20's have less displacement so we don't need as much air ingestion on the low lobe, so if you put TSX cams on both, you are gonna have very large low lobes in and out, which may hurt your low end. It's hard to say because no one hardly does all the work to test it twice.
Well after 2 hours of reading what I see for the k20z1 is people talk the most about add the 06 tsx exhaust cam only, but there’s some people talking about adding the 06 tsx intake cam too, all the post I’ve read compare the k20a2 with tsx cams and itr cams and the k20a with tsx and itr cams but there isn’t a lot of information of k20z1 with tsx cams, I would like to heard from somebody who actually did the swap in their z1
1 - 14 of 14 Posts
