1 - 20 of 21 Posts
I installed this last week and I have the infamous exhaust noise while wot shifting and high rpm decel, I knew this would happen but my question is will buying a torque damper eliminate this issue and the risk of cracking the header / damaging the flex section. And yes I did search but all I seem to find is esmm inserts will stop this but I'd rather pay more for an easier install if it will stop the exhaust from hitting the chasis.
cliff notes= will a torque damper stop my exhaust from hitting the chasis of the vehicle?
Tennis Physicist.
Yeah, a lot of guys have said that the Torque Damper didn't really do much for them.
I have the ESMM inserts and at first the vibrations are whack but give it a week and you get used to it. Also, it makes the car feel a lot more firm and smooth when shifting when WOT.
ok i will take your guys word for it and buy the inserts , and one more question. I have access to a lift so i was wondering if I can do the inserts in the air or do I need to support the motor with a jack of some sort?
Discussion Starter · #8 ·
thanks for link bro
GT30R > Traction
just spend a little more and get real mounts!!!
Discussion Starter · #15 ·
damn i just read the install and it mentions with the stock header I need to remove the dp section of it , will i need to completely remove the dc race header in order to install these?
DC5 Krew
search button is a magical tool
coksukermotherfukertits
Someone correct me if I'm wrong but I don't think you have to remove the header or even the sub frame to install the inserts.
When I installed my esmm's I didn't have to lower the subframe at all. Now in retrospect after replacing them with Innovatives I probably should have as it would have been easier.
I think the rear mount might be in the way with the header there.
Discussion Starter · #19 ·
man that sucks to hear , i really didnt wanna remove it again but at least it will be easier than removing the stock exhaust manifold
you don't have to remove it. It'll be easier of course but you could always loosen all the bolts and move it a little to give you some slack.
1 - 20 of 21 Posts
