1 - 4 of 4 Posts
I Don't Even
If a stage 1 is boosting 8-12 psi w/ the stock internals and a stage 2 is boosting 8-12 psi also W/ the provided new internals*pistons and etc* the stage 2 has a higher chance to last longer. yes or no? would it be better to pay the extra $$$ for the stage 2? yes? :dontknow:
if those are true...then how come more people are not doing it? is it the cost? if so how much is the price difference?
:dontknow: just random thoughts i had :)
If you are referring to a CN stage II, the psi is usually in the 18psi range. If you are only planning on running 12psi you would be better of sticking with a stage I kit and running 10psi. If you want to boost 18+ then you will need to upgrade the internals.
If you are referring to another Manufactures Stage II then someone else will have to chime in.
I Don't Even
wow thanks for the quick reply :D yea i was referring to CN...so if you have the stage 2 its MANDATORY to boost 18+ psi?
1 - 4 of 4 Posts
