1 - 2 of 2 Posts
dustinhurley said:
Why does the Greddy kit require using thermo-cloth and the other kits don't?
How do you adjust the boost pressure on an internally wastegated turbo like Greddy?
Location of turbo - if you dont wrap your power steering line the hose will eventually burn out since it sits right next to the turbo - the CN kit mounts the turbo below so no lines are in the way
To raise the boost pressure on the greddy kit you can get either a manual boost controller or electronic...to lower boost pressure you have to loosen the actuator arm so that the wastegate opens sooner
1 - 2 of 2 Posts
