1 - 20 of 20 Posts
Does anyone know if there is a diy for replacing a clip in the rear bumper. My bumper sticks out on the left side and I think its because a clip broke. Thanks.
I was looking around for a DIY but couldnt find one. Do you know where to get he rear bumper clips at?
I had this happen to mine too, but I found the problem.
It's because the bracket that's holding up your bumper is not screwed into your taillights. When you went to take off your taillights, you probably thought those screws were unneccessary, but they're actually what holds the brackets up. Without those, your bumper will start sagging, and that part on the side will stick out like you said.
Discussion Starter #10
What do I need to do to fix that. I guess it was the guy before me that forgot to put those screws in. Do I need to take my taillights out to get to that bracket?
everything
same problem here. looks like my bumper sticks out from under the tail light a little. looks like the clip may be broken, though. any way to fix DIY?
everything
ok here is an image:
you can see where there should be an attachment right under that tail light. looks like mine is missing a piece. easy fix?
Michael Brown wannabe
one of the clips that holds the bumper must be broken, mine broke after a fender bender and the shop "fixed" it, when i went to take the bumper off to replace my taillight gaskets i had to unscrew a fucking rusted screw that was holding the bumper right at the seem, fuckers didnt even put back the screws that go under the tail light :firemad:
Pancakes
I made a new piece that hold the front bumper in at a piece of picture wire and some duct tape. All you have to do it get it to where the factory clip catches it.
1 - 20 of 20 Posts
