1 - 2 of 2 Posts
· Back Home
Just surfing the web for parts and came across these. Figured I'm probably not the only one that likes to over engineer stuff while tweaking the car.
Rear Sway Bar Reinforcement Brackets for the 06+ Civic!!!
(pretty sure they fit everything though.)
http://www.redshiftmotorsports.com/RedShift%2006%20Civic%20Reinforcements.htm
This bracket is 3/16" thick (150% thicker than the OE bracket) and is made of laser cut CNC'd T304 Stainless Steel. The two smaller holes are threaded and it will come with both bolts necessary to install the bracket. You will need to drill a hole for the second hole on the bracket in order to get full support out of the bracket. The bracket will be placed on the rear side of the vehicle, closer to the rear bumper, the opposite side of the end link.
1 - 2 of 2 Posts
