1 - 14 of 14 Posts
Buying
Hey guys, im buying an 05 rsx type s this weekend and the guy im buying it from debadged the car completely. Any tips or things i should know about rebadging it. I really like to have the rsx and type s on the back.
OG Base Crew
3M double side tape. Works for decklids should work for badges.
If your buying the badges from acura or probably any where they should have a sticky back side so you can stick right on.
Dont use 3m tape, a rear deck lid is way different then a tiny emblem.
OG Base Crew
I guess they are, well it also worked when I reattached my emblems to let the car go. I cut out the old dry adhesive and replaced it with 3m, took some carving with a razor but held up fine.
exactly what you should do.
:face:what do you think is on the back of those badges you bought? an equivalent of 3m double sided tape.
OG Base Crew
I thought so too, even looked like it. :rotfl:
But I'm sure if you do buy brand new emblems from a dealership they might have new adhesive for ya.
Its Always Sunny...
I used 3m emblem adhesive found at like advanced auto, had them emblems on for about 6 months, got bored and they came right off, little reside. Id recommend it
OG Base Crew
Yep reliable vendor for BNIB parts.
My bad, i thought it was a adhesive type glue on the back of them with a peel off instead of the tape, i can see the bigger ones being used with tape but i was thinking more on the acura emblem its self since its thinner.
1 - 14 of 14 Posts
