1 - 8 of 8 Posts
Professional Detailer
Hey did this detail after being contacted by member Ross. He wanted to clean up the paint and remove some of the swirls and holograms left by another detailer. I had limited time to work with the car per owner request but the time I had I was able to remove all holograms and most of the swirls and other fine scratches. The car came out really good and the metallic flake really popped when complete.
Wash
Clay
Optimum Polish via white pad @ 1200 - 1700 - 1200
Optimum Poli-Seal via white pad @ speed 6 on PC
Meguiars # 26 via red pad @ speed 5 on PC
Removed with Optimum Car Wax
Not many before pictures cause I needed to get to work on it.
Discussion Starter · #2 ·
Absolute Pro-Formance
Looks great. In for pics of the SSM tho.
do spray conditioner on the pad beforre u use any optimum stuff?.. and also, can poli-seal be used fine with a gray or blue pad?
i sometimes spray the pad before polishing. I just spray a little quick detailer sometimes or water. As for the poli-seal, its an AIO product so you can use whatever pad you want. The more aggressive pad you use, the more it will cut. Either orange or white is perfect though.
1 - 8 of 8 Posts
