1 - 7 of 7 Posts
These Colors Might Run
I need to reinstall my stock header/cat so I can register my car in CA. The problem is, I left it outside and it has some dirt inside the pipes from rain splash. I cleaned it out the best i could with simple green and paper towels, but of course there's still some dirt in there.
don't give me a hard time about my header getting dirty; it was stupid.
My question: does anybody think i'll have problems if I install it and run the car for a few days to get it smogged? I don't want flaming bits of dirt running through my exhaust system. To be clear, there's a very small amount of dirt in there. It's not visibly dirty or anything. I would just like to know if it need to be PERFECTLY clean.
Thanks for your help! I'll be gone for a little while taking off my race header, but then I'll check back here.
I can drive up your rsx
I'm sure you'll be fine
Fix it 'til it's broken
Exhaust gases will burn up whatever is left, you're fine.
( ͡° ͜ʖ ͡°)
unless by some act of nature some dirty finds its way inside of the head, then yes, you will be :thumbsup:
I would be most concerned with the o2 sensors since it doesn't take much to jack them up.
Hell, just run the car for a few minutes open header, that'll do the trick.
1 - 7 of 7 Posts
