1 - 6 of 6 Posts
How is this done? I didn't see anything in the helms about it but i have a pdf version so i might have scrolled though it. anyone have a page number or instructions on how to do this. I dont want to just go hank it out because i cant it to close back up again. thanks
there are four screws that you have to remove from behind. You need to remove the 2 lower plastic piecs under the dash to get to the screws. It's a pain the bhutt to do.
There was a pdf version on here but I know the link is probably shut down by now. I have it saved so if someone can host it I'll email it to them cause I don't know how to host things.
it is still easily found with a simple search...thats all i'll say (the manual)
and the cointray is a B***H to remove. i took it out to install my strobe switches in. you have to reach up under the dash back to behind the cointray and take out some screws. its a PITA, find some1 with TINY hands to help you
8" member
center consol does not need to be removed. all u do is remove your shiftknob, take out the center plastic piece. reach underneath the coin holder and push up. you'll have to maneuver your hands around the shifter cables but u can do it without all the hassle
1 - 6 of 6 Posts
