1 - 15 of 15 Posts
Super Moderator
I would use some "goo-gone" and a cloth. Pour goo gone on the cloth and rub the glue. Keep using a new spot on cloth till gone. Found everywhere from Autozone to Walmart
Member Master
a product called acry-solv works wonders for removing sticky stuff off dashboards, comes right off with one swipe
Maximum Plaid FTW
Posted from an iPhone
If the dash is anything like the door panel material, I would advise not to use it. I just used Goo-Gone on my plastic door panel and it turned a portion of the plastic to a faded white color after trying to remove a stain.
Doesn't Give A F*ck
good luck
The only enemy of super glue: acetone
It's a powerful solvent. I've had it melt Legos and other plastic toys when I was a child. I'd also be concerned with acetone discoloring the plastic.
Be careful - straight acetone will discolor a number of fabrics and can mar the finish of laminated counter tops (mainly the darker colored ones)
http://www.supergluecorp.com/removingsuperglue.html
Perhaps a Mr Clean Magic Eraser might work.
http://www.autogeekonline.net/forum...rglue-my-car-paint-how-do-i-take-all-off.html
doing stuff
put a-spec trim back on
1 - 15 of 15 Posts
