1 - 4 of 4 Posts
Hello,
I have deleted abs and a bunch of other crap over the years. My question is can I just trace back the wires to basically the fuse box and just remove it along with the fuse? Same with my srs plugs under my seats and stereo stuff since I don’t have any of that.
Just seeing if anyone has done this thenselves or run into any issues.
Thanks
WILDCARD!
Just curious...what's your intent? Weight reduction? Clean up? Both?
I can't imagine that you'd get any significant weight reduction by pulling a few wires out, and if they're hidden under the dash, you're really going to clean things up either. Why not just leave them? You never know what someone else might want to do with the car some day when it's sold.
Discussion Starter #4
you'll need to check the wiring diagrams in the FSM and find everything on each circuit
you can get the FSM from the link in my sig. here is this to start:
Thanks I appreciate it!
Main reason for doing all that is to clean up and remove all the wires I am no longer using like abs which is a big cluster of wires and all the airbag seat wiring. I’ve had this car for over 8-9yrs and it’s slowly turning into a weekend track car. I don’t think I’ll get rid of this car again and if I do it’ll be completely parted out and shell will be recycled
1 - 4 of 4 Posts
