1 - 2 of 2 Posts
Other than the obvious new CV assembly what will I need? New bolts?
Pins? Grease? This is going to be my first major job on a car, ever... So I'm a newbie. Include tools or even a link that could help me if you want! Thank you all!
Since it's your first time. I'm assuming that your purchasing a complete OEM replacement, so it should come with spindle nut and already greased up and ready to go. If that's the case then. breaker bar, I believe it's a 32mm socket for spindle nut, and large flat head screw driver or pry bar. I didn't see any DIY's specific to Ep3, but if you youtube replacing CV axle for civic. the steps are all pretty much the same, just be careful not to tear the new boot, but also remember you'll have to be a little aggressive to get the new axle in. GL, with the youtube visual aid you should be good!
1 - 2 of 2 Posts
