1 - 12 of 12 Posts
touge runner
Yo guys i know theres a thread on resetting the ecu already but it doesnt solve much? Im wondering where exactly do i have to unplug to reset the ecu? People has been saying thats its in the fuse box but exactly where? is there any diagram or anything or pictures anyone can post to help another rsxer out? thanks
btw. im trying to reset my ecu cuz my cars been eating alot of gas lately and im hoping if i reset the ecu it'll relearn everything and also incorporate the intake and exhaust i added to my car. Also I'm hoping it'll fix my car when it starts in the morning cuz it's been starting alot later than it used to. :baby: help a noob
Special K
You can also remove negative griund wire.
Or follow the main power line from the battery, to the fuse box where it enters is a main fuse, kinda large just pull that one, also should have a diagram on the lid of the fuse box under the hood. should be like a main 80- amp fuse. pull it for about 10 minutes.
touge runner
i need more detail.... what exactly do i have to remove? than what do i do after i remove it? some people said leave the car idle for 10 mins? some say keep the rpm at 3000 for 10 mins..... wth?
www.magtuning.com
Open your driver side door
Pull the latch to open the hood
close the driver side door
Support the hood with the factory rod hood support thingy
Get a socket wrench with a #10 socket
Put the socket wrench on to the nut that is on the negative(black) side of the battery
Unscrew until you can pull the wire OFF of the battery
wait a few minutes
put wire back on to battery
re tighten the negative back on to the battery
while holding the hood, remove rod from hood hole
place rod back in to position
close hood and latch hood
open your driver side door
get in
shut door
place key in ignition
push clutch in and turn key until engine has started
remove gear shifter from gear and in to neutral
release clutch
foot on break
ebrake down
clutch in
place shifter in reverse or 1st
driver around
come back and park
open driver side door
get out
close driver side door
go in side house and tell that bitch to make me a sammich
touge runner
Discussion Starter · #9 ·
LOLOLOL!!! this probably is THE MOST PRECISE detailed advice i've ever got and you get a rep for that.... now time to go tell my bitch to make me a damn sammich
Premium Member
hey i even gave you the location of the battery code and the fuse number in the other thread. :coffee:
Canon Crew
The fuse is a 15 amp fuse....the diagram for the fuse box is on top of the black lid. Find the fuse, pull it, with the CAR OFF..then replace it back, and then replace everything. Start the car and let it idle for about 10 mins.
then you should be fine.
1 - 12 of 12 Posts
