1 - 11 of 11 Posts
Is this to be done whenever /any/ engine modification is done?
such as exhaust, or intake, or header..etc.
just curious since it looks like my mods will be installed in stages.
what happens if you mod and dont reset the ecu and drive off? you can always reset it at any time right? (I use to have to do this with my old bike occassionally..strange as it sounds depending on the weather)
i would say do it after every mod to let your ecu learn the new mod/air fuel map... however if u don't reset it the ecu will eventually adapt by itself!
yea just reset it every time you put a new mod on your car....
how do u reset ur ecu?
if you have your cd codes or an aftermarket cd player, just unplug your battery for a couple of mins, then hook it back up and let it idle for awhile, then take it out for a spin. valah.
er..wait wait.
whats the "cd codes"? havnt heard of this...please tell. i still have my stock cd player...
Too much hassle...
Why not just remove the ECU fuse for 10 minutes and when you put it back let your ride idle for 10 minutes. :driving:
:wavey:
sawwbuzz said:
er..wait wait.
Every time you disconnect your battery, your system (stock/aftermarket) will ask you for a "code."
Discussion Starter · #9 ·
hrm..that must be in my manual somewhere then (I would hope)
thanks for the heads up...
strange though I had my battery disconnected for some work in january. when I picked up the car I had to reset my cd player settings but never asked for a code. i guess the guys at the shop did that?
but as you pointed out, just removing the fuse alone for 10 minutes or so will clear the ecu? then I wont need the cd codes?
No the code came on a seperate little card - it's not in the manual. If you don't have it, it's no big deal, you just have to stop by the dealer and they'll look it up for you. My dealer actually had it on file, took 30 seconds.
Discussion Starter · #11 ·
ok..gotcha. its in the front of my manual case..
thanks guys
1 - 11 of 11 Posts
