1 - 6 of 6 Posts
What is the best tires to fit a 17x9 5x114.3 35 off set
There is a big fat thread on this...Welcome and I appreciate your zeal. Don't bite off more than you can chew. Rebuild your engine then worry about the bling. As long as your at it...Put some heat on it. New valve springs would be in order, one can only go up and down so many times before she gets pregnant or your just tired. Check the compression if your at 140-150 lbs at that mileage you can go get your rims. Drive it like you stole it until it then.
1 - 6 of 6 Posts
