1 - 20 of 65 Posts
Premium Member
any of you guys be shaving with safety razors? also known as double edge razors?
i have been getting into it recently, and all i have to say is cartridge razors blow fucking chunks. get on the DE train. be patient, because if you've been using cartrige, there's a learning curve, but your face and your dome will thank you for taking the time.
just curious what the rest of you have going. post it up.
S U P E R C H A R G E D
Invest in a decent shave brush too. really makes a difference if you like to let your facial hair get a bit longer before you shave.
I like to go beyond the 5 o'clock shadow. Usually only shave once or twice a week. The brush definitely lathers a lot better than just applying it with your hand.
Premium Member
and what kinda lather/shave soap/etc you like? so far, i have just been using the edge shave gel i had when fucking with cartridges. it works okay, as long as i don't over do it. the DE razor gets clogged if too much, but it doesn't seem to bother a cartridge razor.
Former Mod-Still a God
In on this, I am getting closer to having to shave my done. 28 and top section is thinning a lot. I have kept my hair extremely short over the last 5 years so you cant tell but I will have to clean shave it soon. Looking for some good options. I have done it with a 5 blade before but it was a pain.
Doesn't Give A F*ck
i can't grow a beard.. middle section of my upper lip seem to not be able to grow anything there.
so if i do end up growing it out, people call it a molestashe or i end up looking like the old school japanese emperors.
i shave maybe once a week because of work.
goatee master race here
and what kinda lather/shave soap/etc you like? so far, i have just been using the edge shave gel i had when fucking with cartridges. it works okay, as long as i don't over do it. the DE razor gets clogged if too much, but it doesn't seem to borrow a cartridge razor.
barbasol
usually i'll just shave in the shower cause the steam softens the hair and skin.
Super Moderator
what about balls shaving, it this the thread for that too?
Doesn't Give A F*ck
too scary to shave my balls. one knick and you're bleeding for days.
always wanted to grow out a beard though
Premium Member
Discussion Starter #14
Safety razors here too! You need a legit good quality badger hair brush and good shave soap. I have a classic Merkur razor but use Feather blades as I found them sharper.
Funny they call them safety razors, I guess only safe then a straight edge which I am going to try next. http://www.fendrihan.com/dovo-inox-stainless-steel-straight-razor-olivewood-scales-p-754.html?cPath=116_22_83
word. i have the merkur 34c as well as a merkur long handle. i have been using the feather blades too. nice and sharp, but i find they do require more lubrication to keep from getting nicked.
for shave gel, i have just been using the edge gel, because i have shit tons of it right now. before shaving, i work some nexus humectress conditioner into my face and dome, then i follow it with the edge gel. works pretty well.
i'm trying to decide if i like the long handle razor or not. it's a bit easier to get an angle, but it's not heavy like the shorter handled one, so it takes a little bit of pressure to get a cut.
Premium Member
Discussion Starter #16
need to find a tube shave cream. i don't want to have brush, i don't think i need that, and i want to have a lightweight shaving kit. razor, blades, and shave cream.
1 - 20 of 65 Posts
