1 - 5 of 5 Posts
I plan on doing a K24 swap and I could not find a complete parts list anywhere. I came up with a list that I think covers most of the parts for the swap. If I missed anything, let me know. Part numbers are OEM except for the Eagle Rods and Oil pump spring. This swap is for a K20a2 head on a K24 shortblock. Kpro is a no brainer!
K24 Head Gasket (Use the head gasket that matches the block) (There are differences in the coolant ports on each head gasket)
CRV part# 12251-PPA-004 $57.76
TSX part# 12251-RBB-004 $53.23
S2000 OIL COOLER Joint part# 11107-PT2-000 $5.10 (Must use the K20a2 water pump and water pump housing to use the oil cooler) (If you decide not to use the oil cooler, stick with the K24 water pump)
Hondabond part# 08718-0004
Crv engine mount part# 11910-PPA-000 $28.63
K24 parts needed if buying a shortblock
K24 timing chain 14401-PPA-004 (CRV, Accord)and 14401-RWC-A01 , timing chain cover 11410-PPA-000, timing chain guide tensioner 14520-RAA-A01(TSX), timing chain guide 14530-RZA-A01, timing chain tensioner 14510-PRB-A01 or 14510-RAA-A01(CRV Accord)
K20a2 RSX-S oil pump 15100-PRB-A01 , chain 13441-PCX-004 and baffle plate11221-PNC-000, oil pan 11200-PRB-000 , RSX Oil cooler and oil filter thread and K20a2 crankshaft pulley 13810-RRB-A01.
Mounting RSX oil pump to K24 block will need to be ground down for clearance.
(Crv block NO modification to the oil pump to fit)
Delete Oil Pump Balance shafts.
TSX and Accord needs to be modded
Main Bearing #3 on block. Remove the jet.Plug with a 12mm bolt with hondabond.
Swap k20a2 block sensors to k24a2 block (Crankshaft Position sensors, Knock Sensor, Oil pressure sensor)
Extras!
Power Steering delete with Ep3 Idle pulley and K20a2 crankshaft pulley.Part# 31190-PRA-000, 31175-PRA-000, 31185-PCX-003, and 90031-PRA-000
-Serpentine belt: 64" 7-ribbed or EP3 belt Part# 38920-PNF-004
(Modded Oil Pump for K24)part # 9657K116 RSX oil pump modified spring. Oil pump inlet ported direct and smooth.
http://www.rsx-tuners.com/products.php?product=oil_pump_modifcations (Picture of a ported RSX oil pump)
http://www.mcmaster.com/#catalog/119/1216/=n7cr13 (Increases oil to head and main bearings) (Recommended) $7.19 for 12 springs plus shipping.
K24a2 Eagle Rods Part # CRS5984K3D (K24a2, K24a4, K24a5 ) (Recommended)
ARP Headbolts ARP 208-4701 (Recommended)
Homemade Crankshaft removal tool: 1 1/2" black pipe bushing with a 1 1/2" coupling,that i drilled a 3/4" hole to slide a 2 foot piece of steel rod into.
http://www.k20a.org/forum/showthread.php?t=87911 (Recommended) $10 to build!
K20a2 with K24a2 block compression 10.5:1
[URL="http://
Like I said, its not even close to being a complete list or what is required, all on one page.....
This is exactly why I made a new one. Can you say vague?
is a great small checklist, thanks for sharing it
some people say that the k24 frank will work with the stock PRB ECU, is that true?
1 - 5 of 5 Posts
