After about a month of sitting on these I finally decided to do it, I swapped my RSX seats for a seat of 2011 Honda civic si seats,what a difference in comfort! What I did was grind the legs off the si seats to the bare rail, used a dremel to cut off the legs on the original seats. I then took the legs off the original and bolted them in the car. I just sat the new seats in, and spot tacked them in one leg at a time. After I had it solid I pulled each seat and reinforced them with a healthy weld. Worked great! Now, the next project is dealing with the SRS light . Easy, went on eBay, got an ep3 civic SRS ecu. Same airbag setup, no side airbags! ( or you could just pull the bulb out if your less picky)
