1 - 7 of 7 Posts
Track Whore
I'm getting my Volk rims mounted today, but people telling me to roll my fenders and not. Just need some advice. Thanks :)
Actual drop
Front: 2 finger gap
Rear: 1 1/4 - 1 1/2
Rims: 18x8 +38 offsets
Tires: 225/40/18
aka Batman on weekends
i have 18x8 +35offset/245/35 tires on aspec & rub slightly on fast turns
-0.8 camber up front.
you should be fine with 225 - maybe minor rubbing
Track Whore
People say I will definitely rub when I turn. My ride is bouncier after I had an alignment. The rear is lower then the front and it seems the rear will rub. Still need info on this.
i really cant imagine the rear will rub unless u run crazy negative camber.
my rear offset is +40 and with the same 245/35-18 tires and i run -1 camber & dont rub at all.
Make sure you get camber kits for front & rear if you dont already.
u probably are right - u are too low in the rear - prob need a spacer and/or fender rolling
Track Whore
Yeh. A buddy of mine told me to go all -1 camber, get 215/40/18 tires, and roll the rear fender. Did most of the this today and ended up getting nothing. :(
it might be time to get a 5mm spacer.
Anymore than 5mm and you will need to install longer studs.
good luck
1 - 7 of 7 Posts
