Rumbling sound on right turn*Now With Vids* UPDATED
2395 Views 20 Replies 4 Participants Last post by  Blue_type_s
Alright so here is my situation. I have a rumbling sound that occurs on a right turn only, and only when I give throttle. I am able to take a turn quickly when not on the throttle and the sound does not occur. I thought perhaps it was a wheel bearing, but my mechanic said it wasn't that. I had both of my CV shafts changed as well as a new spindle assembly (on passenger side only) (bearing, ball joint, etc). I can make a left turn and get on the throttle and there is no issues, only on a right turn while on the throttle.
The sound is more of a rumble noise. A wheel bearing is a squealing sound.
I can't seem to figure it out and it is really bothering me. Is there any suggestions on this?
UPDATED:
I am going to try and add a little more detail in hopes that someone can help me out here.
I originally took my car to my mechanic for this rumbling sound. I thought it was a wheel bearing. I got a call from him and he said my wheel bearing is fine and it sounds like something with the transmission. I took it to a transmission mechanic and he said my transmission was fine. He said my passenger side CV shaft was done so he changed that. $500 later and my problem was still there.
It has been bugging me so I did some research on what bad CV shafts symptoms are. Sounded exactly what was wrong with mine. So I took it back to the mechanic and got him to change my driver side CV shaft. Still no luck and back to where we started as well as I have an added sound now. Perfect, just what I need.
So my problem in as much detail as I can. This rumbling sound (as well as sometimes like a clicking type sound) which only happens on a right turn and when I am giving gas. It doesn't matter what gear I am in or what speed, it will still make the noise. When I am at a slow roll (15-25 km/h) when I put it in first I feel/hear a clunk type noise. The sound is only apparent while going through the turn and as soon as I straighten out the wheel the sound goes away. I can also feel the roughness in the steering wheel.
Since my driver side CV shaft has been changed I now get a new sound. It happens after 6000 rpm and sounds like a bom bom bom type sound. You can hear the sound I am referring to in the video near the end. If I downshift so my rpms are above 6k rpm I can hear it as well as if I take it up to redline I can hear the same sound, but not until after the 6k mark.
I really just want this fixed. Could it be my differential? If it were my differential I would be able to hear it all the time correct? I am stumped and looking for some advice. Incase anyone was wondering, amsoil transmission fluid is in there.
Vid 1- I am just manually moving the shaft back and forth...is this how it should sound or does it sound like bad news?
http://s44.photobucket.com/albums/f1/Killa9111/?action=view&current=163.mp4
Vid 2- It is hard to hear the sound I am talking about in the video, but is very loud in person. Near the end of the video you are able to hear the bom bom bom sound I am talking about.
http://s44.photobucket.com/albums/f1/Killa9111/?action=view&current=164.mp4
For the fellow canadians, if anyone thinks they could help me out I am located in Mississauga if someone is willing to help me!
1 - 20 of 21 Posts
Posted from an iPhone
Anyone? It's pretty frustrating
do you feel anything in the steering wheel/chassis when you hear the noise?
where does the noise seem to be coming from?
I feel it in the wheel slightly when im on the throttle and its making the rumbling noise. I don't feel anything in the shifter though.
Well thats the hard part to figure out. Seems like it is coming from the drive line :dontknow:
does the rumbling seem to change based on speed, or engine speed?
like does the rumbling sound the same at, say, 20mph whether you're in 2nd or 3rd? or does it change depending on what gear you're in (higher pitch or faster in 3rd)?
i'm just trying to ask questions that should help everyone figure it out :)
i'm not 100% sure if i'll be able to diagnose it, but i figured the more information we can get the more likely we are to give ideas :)
No they are legit questions, I understand it is hard to diagnose something over the internet and every problem either sounds like a rumble or squeak on here lol
Well the harder I press the throttle on a turn the louder it gets until I get out of the turn then it disappears. If I take the turn like a granny I don't hear it, but give a little throttle and you hear it. Gear doesn't matter, but the same sound occurs.
I asked the transmission guy if it was my differential and he said it wasn't. All my gears shift fine so I am pretty stumped. It seems like the only time I hear it is when there is force on the driver side of the car. I have had it up in the air with it in third gear and turned all the way to the right, but like I said until there is pressure on it I can't hear anything.
Check your motor mounts...the driver's side and passenger side in particular.
On you on OEM mounts or aftermarket?
I had a torn mount on my passenger side once, it made the rumbling sound during a slow corner - especially when lifting off the throttle then getting back into it.
Hope you figure it out.
-J
i'll keep trying to help you diagnose it where i can...i know it sucks not to get a response, so maybe with some discussion we can either figure it out or someone else will chime in with the extra information :)
well since the noise doesn't change based on gearing, you're right...it shouldn't be transmission or engine related (you'd expect it to change with either)
now since it's a rumbling noise that's dependent on taking a hard right than you'd have to assume it's something on the driver side that would be worked more, like you said
i'm almost 100% sure you've done this, but have you double checked your lug nuts are nice and tight? (not hand tight/loose). this shouldn't be the issue, but may as well start cheap first.
another thing that went through my mind when i heard this....is possibly axle related? i haven't had axle problems myself but it seems it'd be part of the chain and possibly make a rumbling noise with throttle if there was a problem with one
EDIT: actually, the mounts are a good suggestion too
Well my motor mounts are stock, but would that cause this issue to only be on a right turn? How can I check to see if they are still good? I had it up on stands a few minutes ago and had it fully cranked right and was giving throttle, couldn't hear it at all. Im stumped
Lug nuts are tight, but sometimes simple things can screw you up.
Well I suppose I could try motor mounts, helps with wheel hop and everything else as well.
I hate car problems!
Basically - that's what I did...had the car on jack stands so I could get up under there w/ a flashlight. Since your mounts are stock - you can inspect them closely to see if the rubber is torn / split in any places. If so, the mount is probably damaged and needs to be replaced. You might be able to visually inspect some things from the topside under the hood...like the driver's side mount.
Unfortunately - my passenger (base model) mount actually had to be unbolted and lifted up to inspect the rubber portion b/c it is hidden when fully installed. I placed a jack under the motor w/ slight tension as I loosened all the bolts/nuts on the mount. The jack helps to keep the alignment somewhat centered to aid in the re-installation process.
Hope this helps...
-J
would a sound like this actually be caused by a bad motor mount? I would just hate to spend the time/money on it and then my problem still be there. I guess I am just getting frustrated since my passenger side cv joint and knuckle assembly was changed and then a nice $400 bill and my problem is still here.
I don't know if there is anything else to explain to you guys to help diagnose my problem. If it were a wheel bearing would I not hear the sound just driving as well? My mechanic says the wheel bearing is fine, but I am just trying to narrow it down myself. I just cant figure out why the rumbling sound is only heard on a right turn and while giving throttle.
ugh I hate car problems.
updated!!
bump
anyone? Can someone help me out....maybe I can meet up with someone in Toronto to have a look?
Ya I'd try to meet with someone in toronto and see if they can help (post in your regional section)
But, the noise you hear, does it seem to be coming from straight ahead of you? It may be your differential but that's not a part that normally (ever?) wears out
It sounds like that could be it from your description though - accelerating through a turn. I wonder if it's just not within tolerances and the higher rpm's kind of exaggerate the problem/sound?
You may also want to post this in the Transmission section for advice specifically about the transmission or differential
My moms Element makes a rubbing grumble loud ass noise on turns as well. We cant figure it out.
Thats almost what it sounds like is a rubbing sound. If it were though I would be able to hear it even when my clutch is pushed in, but I don't.
I have been underneath the car and had my wheel cranked all the way to the right and left it in third gear, yet I can't hear it. It seems like there has to be a load on it somewhere.
I am very confused and frustrated. Especially since I have taken it to a few mechanics and they don't know what it is either. Its like its a mystery noise.
Thanks for your help!
Well after many aggravations an 18 year old solved my problem. Turns out my front mount is done causing it to vibrate on the metal making my fabulous noise!
Thanks for everyone's help
-J
Glad you finally figured it out haha - damn OEM mounts.
-J
1 - 20 of 21 Posts
