1 - 4 of 4 Posts
I was about to buy the reflash, but on the clubrsx order form it says that i need the ecu serial number........but i cant find out where to find the number. is it directly on the ecu itself? cause i took off the panel beneath the glove box and my number isnt on the side facing towards the ground, would the number be anywhere else? thx
You have to pull the ecu out of it's little holders. You can't see it if all you do is remove the kick panel.
ECU Tuner
daburtonmaster said:
yea i found it, thanks
This can also be a drag when you sit at your computer and want to order the upgrade or reflash just to find that the order form wants the number. Well, you can't always go out to your car and take the ECU out to find the number. It's okay with ClubRSX if you simply fill in "Serial # will be provided." It's really Hondata that needs the number and they can get it from your ECU.
1 - 4 of 4 Posts
