1 - 12 of 12 Posts
Yesterday while driving home, I was making a left turn but made it too wide and ran into a curb pretty hard... :dontknow: Anyways, my rims are curbed really fucking bad and my steering wheel now shakes when I got faster than 60+mph. What do you think happened? Could my alignment have messed up because of that?
Boostalk!
First: How the fuck do you make a LEFT turn too wide? I'm betting you suck at driving, because if you drove correctly, you would have hit the left lane on the street you were entering, making any possibility of hitting a curb null and void. Second, you have fucked up your alignment. You have probably also damaged your tie rods.
Damn you're mean as hell. I just made a mistake while driving, geez.
Breast inspector by appt.
Take your car to a good alignment shop. Tell them the story, they will give the car a good look over and give you the bad news. It's most likely that you have some bent components, some of them, like the lower control arm, are designed to give under impact to reduce the chance of more expensive damage, like to the car frame. Get the problem parts replaced and then get it aligned. You may also need new rims. You might be lucky and get away with a couple of hundred, or you might end up like me when my kid curbed by wife's KIA, one new rim and one new control arm, 750 bucks, and that's with me doing all the work.
Type-Jeff:
It could just be that one or both of your front wheels are out of balance. This could be especially true if one or more of your wheels got banged up. YOu may need to replace your wheels and get them rebalanced.
good luck
Boostalk!
Not mean, I just have a hard time with things I don't understand. A friend of mine hit a curb after dozing off, and it was soft. He fucked his tie rod.
Speedy
bent wheel - time for a new one....
Car Is Sold!
How's the steering? Is it still centered? Does it pull to one direction? Could have possibly knocked some weights off the wheel/tire. Most likely the alignment is off as well. Just have it aligned and have the wheel re-balanced.
1 - 12 of 12 Posts
