1 - 5 of 5 Posts
this is my inner child
I have everything hooked up but I'm not getting a light at my set rpm. Doesn't the blue wire under the hood that I can use for my rpms has a plastic connector at the end of so a tech can connect to it?
That is correct.
Make sure that the tach wire is seated well in metal clips in the plastic connector. Maybe, try different pills to make sure the pill is not bad. If all your pills are bad then the light is probalby not hooked up right. Make sure your got a good ground. :dontknow:
Actually mine doesn't have pills. I just program it for say 7400 and it's set. Monday I notice the light did come on at like 8200 when I had it set for 7700. So last night I set it to 7400 and tried it this morning on the way to work and it didn't work.:firemad:
I'm about to pull the whole thing out and set fire to it.
So, is this one of those ones that you set manually by revving the engine to, say 7400 and pushing a button, or turning a nob? If so, those are nasty to set up.
Discussion Starter #5
No, I basically punch in the RPM I want the light to come on. I don't have to rev the car to desire rpm and then hit a button. Works kinda of like setting an alarm for an alarm clock.
1 - 5 of 5 Posts
