1 - 1 of 1 Posts
Super Moderator
You may have come across an car listing that says the vehicle in question has a rebuilt engine, but what does that mean?
An engine can wear to the point of being unable to perform adequately. At that stage, it must be taken apart and then put back together with new parts to replace the worn components. Tell tale signs of an engine that needs to be rebuilt include high oil consumption and white smoke coming from the tail pipe.
Rebuilding an engine is a detailed process that includes the cleaning and assessment of the short block, replacement of the piston rings, bearings or other components in addition to reconditioning of the cylinders in order to make sure the engine is in top shape.
Where was it rebuilt?
Troy Snyder is the chief operating officer of NADA Guides, a publication that follows the transaction prices of used cars. The folks at NADA Guides offer good insight into the value of used cars. “A rebuilt engine can be as good as the OEM one,” Snyder said. “Sometimes a rebuilt engine can maintain the original engine warranty.”
If you’re looking at a car with a rebuilt engine, he said that you should look at where the service was performed. “Certain organizations (like a dealership) are trusted to handle such a job,” she said. “If you go down to your regular mechanics shop there’s more risk involved.”
What do you think? Read Should I Buy A Car With A Rebuilt Engine at AutoGuide.com to learn more and discuss.
1 - 1 of 1 Posts
