1 - 7 of 7 Posts
it doesnt go ne faster!!!
Hey guys,
not sure where to post this but i got a used 2003 Optional Side Skirt and want to install it myself. Only thing is i am missing the template used to mark where to drill, does anyone happen to have a scale size of th is template so i can use it to mark where to drill the holes?
thanks alot if you can help!
:bow:
I may drill mine just to be fancy :) the best way to do it without the template is to install the skirts with all the other points mounted, then you can just center punch it where the bracket lines up with the car.
Take the strake off, drill the whole (3mm, then 6mm, then 10mm), remount the strake; now utilizing the new hole.
1 - 7 of 7 Posts
