signal lights
368 Views 2 Replies 2 Participants Last post by  thebluedc5
so after after oil change last night my signal lights dont signal when i wanna go left or right.... BUT my hazard lights work.....all i did was a oil change and didnt touch anything else.... i check all the fuse and stuff too! when i use the signal.. the green arrow light in the cluster wont go on and when u outside the car . u dont see the signal light flash either!
1 - 3 of 3 Posts
If the hazards work OK, the most likely problem is a blown fuse 19 (7.5A) in the under-dash fuse box. (The ignition switch has to be on for the signal lights to work.)
haha i was messing around wit it this morning and i was playing with the harzard button like clicking it few times then i try to signal and it works? is it the wires loose or something in the hazard harness?
1 - 3 of 3 Posts
