1 - 9 of 9 Posts
firstly, check your fuses (sorry i don't have/know the fuses off hand though)
do you have sidemarkers, possibly tied to the turn signals?
wtfhax0r
done any radio work recently? i remember i forgot to connect the plug behind the headunit to the hazards button and it cut power to everything
Grand Master Member
yea..i will go ahead check the fuses..is it the one in engine bay or under the dash?
i'm pretty sure it's going to be one under the hood
if you don't have an answer for which one later, i'll try to find my manual....there's a diagram in the owner's manual explaining what each fuse is for (well....very brief description of each)
Grand Master Member
thank u very much~
Shiny side up!
02-04 fuses under hood #19 100AMP/ #20/ 40AMP USA Model./50AMP/ Canadian / #5 /15AMP......under dash #19 /7.5 AMP
Shiny side up!
Check these fuses as i have listed .Then if not those try the hazard switch .....Flick it on and off a dozen times or so (sounds weird but it works ) the relay is in the under dash fuse box above the group of fuses to the right side outer edge of the box . Three prong contact remove and beat on that if needed .
1 - 9 of 9 Posts
