1 - 20 of 27 Posts
Royale with cheese.
What size is the piping on the mugen exhaust?
Mugen Airbox and Exhaust are pretty much the combo to go with correct?
one more:
How will mugen exhaust/airbox combo work with the Toda N2 Kit and Header? I am not sure if i should get a CAI instead of the airbox because it would work better with the ECU reprogram. Thanks :blah:
one more:
Check sig. Strong combination without the N2 cams, which I plan on switching my ITRs out for soon. As for the airbox, I imagine it will not work as well with the reflash as the CAI, but if you go with the K-Pro, then you will be able to tune it properly.
Royale with cheese.
thanks, but do you know how big the piping is?
Royale with cheese.
and how did you only put down 204 whp?
because my whp is SAE corrected. If I were to use the technique that everyone else seems to use, which is to post STD horsepower, my output would have been more like 213 or 214. Also, my A/F was off with the K20A flash. I have a K-Pro on the way now.
Also, look for my dyno. If you notice 204 was the peak, but my midrange is VERY strong and lacks the ever-so-hateful VTEC dip.
AS for diameter, it is 60mm.
Royale with cheese.
so about 2.4 inches, not too shabby, thanks bigdawg!
Yea, it is right at 2.36 or something.
Yeah the camps are only $600.
Not bad of a price... I was reading your thread.. and was thinking HE Should Put The N2 Cams.
Good Luck with everything! :thumbsup:
Royale with cheese.
Discussion Starter · #9 ·
N2s are crazy sweet
Oh it is in the future.
Royale with cheese.
Discussion Starter · #11 ·
you gotta update us on the gains when you are done...
I will post new dynos with my current setup+K-Pro when I am done tuning(should be next weekend).
Royale with cheese.
Discussion Starter · #13 ·
alright, sounds good.
2 Peter 1:2
I was told that the Mugen necks down to 2 inches when it loops into the muffler.
Royale with cheese.
Discussion Starter · #15 ·
is this true? im on tein ss at max drop and i dont want to be scraping my 1000 dollar exhaust
2 Peter 1:2
The piping is not 2 inches off the ground. The piping diameter shrinks from 2.36 to 2 inches when it loops back through the muffler. John from Hytech gave me this info and cited that in comparison, the Hytech twinloop is a constant diameter throughout the whole exhaust.
Royale with cheese.
Discussion Starter · #17 ·
ohh i see, so this could prevent future problems if i go N2 kit, etc?
Royale with cheese.
Discussion Starter · #18 ·
damn i really wanted this mugen exhaust!!
Would you like to see a pic to show that it does not?
1 - 20 of 27 Posts
