1 - 10 of 10 Posts
Addicted Tuning Tweaker
I just installed the skunk2 Pro-S coilovers and for the first time exceeded 100mph. It was scary as hell. My car seemed to want to go every which way but straight. It is fine below 80. Is this due to the height setting? Should I make the front/back lower or higher?
I will very extremely disappointed if these are poorly designed "performance" equipment that I have just paid to degrade my car. :(
Special Olympics Winner
the skunk2 pro-s are pretty dece coils man i think your car just might need a allignment now that you installed them, that or your tires need a balance
Civic Si Member
yeah i got pro-s on my 06 si n i love them... they r great for the price
I'm dropped on Skunk2 coilovers, and they are VERY bouncy esp. at highway speeds (approx. 60-80mph). From other people I've talked to it seems that this is pretty common.
Get realigned see if it helps but I don't think this a serious problem, just the nature of the beast, and in all honesty I hope you don't/won't exceed 100mph so that its nothing more than a minor annoyance.
Discussion Starter #6
Good info
Thanks for the replys that is great info. I am taking it in for an alignment tomorrow. I'll retest and see. It is a minor annoyance but it could become much more when I go to the track. Well have to see. If they don't improve I might have to get something else but the low speed performance is so inspiring that I am hopeful that the alignment will do the trick.
maybe you should drive within speed limits.
I can drive up your rsx
Two problems here.....
You are driving too fast and too furious
You bought something from Junk2
Discussion Starter #10
Finally seems better
Well, after replacing the right rear lower control arm, knuckle, and camber equipment for the front and rear it finally aligned to spec.
It is still a small bit suirrelly at high speed but I attribute that to caster changes due to lowering. It does track straight and feels good at most everything below 90.
I bought skunk2 coilovers because I read here on crsx that people liked them and they made good products. Some of the posts about "junk2" and such concern me...
1 - 10 of 10 Posts
