1 - 6 of 6 Posts
I just got a used 02 rsx and it's good but the ride is pretty stiff is there something i could do so i don't feel every rock and bump I drive over
Hard to say without more info. Verify all your suspension is stock and make sure your tires aren't over inflated.
Get some 15s with a taller sidewall.
Check and make sure you don't have coilovers. You can switch back to OEM struts but for the most part the RSX does not have a comfortable ride stock.You can also switch to 02-04 15" wheels which will give you a taller sidewall. If a Honda Civic is too stiff for you, look into getting a bigger car like a Camry or Accord.
02-04 never came with 15” wheels. Even the base models are 16”
Tbh 15s would look pretty weird on a Rsx though.
Reactions: dustin02rsx
1 - 6 of 6 Posts
