1 - 10 of 10 Posts
will 02-03 tein springs & shocks fit on the 05-06 model?
if so is there any differnce in how it will ride or is it the same exact thing?
Discussion Starter · #2 ·
also... why is it when u take off suspension on the rsx's and put it back on the alignment goes way out of wack... not like on a eg civic or a dc teg... u can do that with no issues...
GT30R > Traction
if your just trying to swap the springs it's not going to work, the front are wound in different directions for the different years. If your swapping the whole suspention then they will fit. By springs and shocks you must mean coilovers and those will fit on both years. also anytime you change your suspentino your alignment is going to change....fact of life not car.
广州本田
Yes if you change the whole coilover assembly it will fit
Changing any cars suspension geometry will affect alignment, sometimes more sometimes less, need less to say an alignment is a must after even a small suspension adjustment.
ciao-su!
if you change out the spring AND shocks from the 02-04 and put them on the 05/06, then it will fit. BUT if you just take the springs from the 02-04, then they won't fit on the 05/06. something like the springs are wound a different way, something something
also, the alignment goes out of whack because of how our suspension is set up. I am no pro at this info, but i'm pretty sure it's been covered before. maybe someone with more knowledge can chime in. if not, i'm sure you can find the answer by searching
ok one more question... a guy is sellin 02-03 tien s techs mounted on stock shocks but they are off a base model
will that bolt rite onto my 05-06 TYPE S
GT30R > Traction
^^^^yep will work
DC5 Krew
u have to do a direct suspension swap
1 - 10 of 10 Posts
