1 - 8 of 8 Posts
jsut a question. is there an incorrect way to install lowering springs. what i mean is, is it possible to put them upside down. the reason im asking is because the springs are only supposed to be 1.4 inches lowered in the rear. and it looks like its slammed. (well to me that is) but can any one help me out.
do a barrel roll!!
you def put it on upside down, see springs only go one way, if you put it on right way up it would have dropped it 1.4" exactly, but you put it upside down so now it dropped it 4.1", there should be a little arrow on the spring that tells you right side up. :thumbsup:
HONDA PACT
some springs sang in the rear and some look lower in the rear because the fender line is lower in the rear
12 Volt Installer
BAAHAHAHAHAHAHHAHAHHA
your not serious right?? i didnt think so.
American HP!!
:rotfl::rotfl::rotfl::rotfl::rotfl::rotfl:
wish I could rep you
GT30R > Traction
dosn't matter unless they are progressivly wound on one side. let them settle, but the back will look lower then the rear with a lot of springs.
dolan pls
wat :rotfl:
1 - 8 of 8 Posts
