1 - 2 of 2 Posts
Hi!
So currently my 03 RSX is out of commission due to starting issues.
Before this had happened my car would have a weak start, but it would still manage to start & it would get weaker as time passed. Eventually no start & one single click.
I checked the battery first of course & the positive terminal was so corroded! It was piled! So i cleaned as much as I could thinking that was the issue, but nothing. I checked the battery and it was still good.
I checked the fuses and none were blown
I haven't checked my starter relay but everytime I turn the key and slowly turn the key back there's a buzzing noise from the relay?
I cleaned out the contacts on my ignition switch, but nothing.
Everything still comes on; all lights, A/C, Radio, no dim headlights.
I haven't done the starter, but I really don't have the funds atm to change it.
Any ideas would be appreciated. Thanks!
not very much faster than an FRS
Replace the positive terminal and see if that does it. $3.12 on Mcmaster Carr, I hope you can afford that.
1 - 2 of 2 Posts
