can you try to explain what the noise sounds like?
hey guys I need a hand on this !! When i turn my wheel all the way to the left .. it seems like something on the front passenger side is making a noise .. like some cracking... It seems to be something related to the steering. any help ???
Also, my other concern is: my car at around 45 to 55 mph makes a really loud noise.. it seems to be either a wheel bearing or my cheap (wyndstar) tires.. I've heard that cheap -low profile- tires are supposed to make a noise.. but I'm not sure if it's a wheel bearing or the tires... any help ??? It'd be appreciated.
My only mod suspension is Tein S lowering springs !! is there anything else I should change suspension wise in order to help the shocks ? is it a common problem the one I'm having? .
Thanks.
yea, I'd check for low PS fluid levels. There is only one belt in the RSX, and its goes over all the pulliesCheck to see if your power steering is leaking and/or if the power steering belt is worn.
already did.. SORRY BROPlease![]()
Mindless :chuck:
that's what I'm thinking it may be... a CV join... hope NOT :run:Have you checked the CV joints. It doesn't sound like it from your description of the noise but it could be a bad CV joint. Check the boot to see if its torn.
