1 - 20 of 65 Posts
Welcome, I am here to announce that I will be starting my own install services this summer at my house in Bellflower (562). Installs will be by appointment only and by texting me, Steven, at (562)650-7868.
About me: My name is Steven Saari, I'm 28, and I'm currently working on my bachelors degree towards Mechanical Engineering at CSULB. I served 4 years in the United States Air Force (2006-2010) as an F-16 fighter jet mechanic. Basically, I did all work on this aircraft (picture below), ranging from engine changes, landing gear changes, hydraulic component changes, etc.
If it was bolted on to the jet, I changed it.
I've been working on cars as a hobby since 2008 and I currently mod my 2003 Acura RSX Type-S and 2007 S2000.
I am very organized and meticulous with my work and I take pride in what I do.
Text me what you need done and I will happily help you with your modding needs.
The following is a list of services & installs I can provide (but not limited to):
Engine:
- Intake manifold remove & install (r&i), intake r&i, header r&i, exhaust r&i, engine sensor r&i, valve clearance adjustments, oil changes, coolant flushes, serpentine belt r&i, a/c compressor r&i, power steering r&i, alternator r&i, battery r&i, throttle body r&i, plus more!
- I also can do engine changes (I k24 swapped my rsx), clutch changes (along with flywheel and pressure plate), and transmission changes but I will not do that for free. Text me and I'll be glad to do those for a reasonable price.
Suspension:
- coilover r&i, swaybar r&i, strut bar r&i, camber kit r&i, lowering spring r&i, wheel r&i, lower control arm r&i, brake pad r&i, brake rotor r&i, brake caliper r&i, brake and clutch stainless steel line r&i, brake and clutch fluid flushes,wheel r&i, lower control arm r&i, brake pad r&i, brake rotor r&i, brake caliper r&i, brake and clutch stainless steel line r&i, brake and clutch fluid flushes, plus more!
Interior:
headunit r&i, speaker r&i, display gauge r&i, ecu r&i, seat & seat rail r&i, plus more!
I can also do the DIY black headlight painting.
Thanks for taking the time to read this and I hope to hear from you guys soon!
Super Moderator
wow that is awesome, a great way to get your name out and things going. good luck with everything, we got a guy over here that does those work too, ppl like you really help the rest of us out and avoid getting rape at the shops
LAKERS ALL DAY EVERYDAY!
bump for fellow serviceman :bow:
vvvv My Bitch
Would be much appreciated if you could help me out with installing sway bar. Since I got race header and exhaust my em2 sway bar just sitting in garage. Thanks
Discussion Starter #10
Thanks for the support guys. Sorry for the late responses here but I have finals coming up, last one being a week from today. Please feel free to text me for quicker responses!
Discussion Starter #14 (Edited)
For fast responses, text me at (562)650-7868. I have a lot of time on my hands this summer so hit me up with what you need done and we can figure out a price!
Discussion Starter #19
I still haven't listed my service fees but text me with what you need done and I'll let you know. I'm also going to start listing appointments here. Thanks!
1 - 20 of 65 Posts
