1 - 9 of 9 Posts
I searched around for a bit and i just couldn't seem to find it so i figured i would post...
Anyways i'm planning to get an Aftermarket HU (IDA-X100) next weekend and i was told by Store that my Stock Sub and Amp wouldn't work no more even if i don't do a Amp Bypass and use a wire harness. I was just wondering if that was true and if i can use stock sub and amp after i get the HU?
Thanks in advance, much appreciated
The Audio Guru
wrong, use the Metra 70-1725 integration harness and the stock amp and sub will work fine.
i have a question similar to his...
i'm thinking about getting a Premier p600ub hu and was wondering if i should bypass the bose amp or integrate it? i've read about hu with integrated amp somewhere, is this deck one of those?
140 lb-ft of fury
I have the same HU. Be sure to bypass the oem Bose amp, or else your sound will be greatly distorted. Very easy and only takes 10-15 minutes. Good choice on HU.
http://forums.clubrsx.com/showthread.php?s=&threadid=46972
The Audio Guru
only if you are not using the integration harness, if you are wiring up directly with the 70-1721 harness yes you will cause all sorts of problems as it is made for cars w/o the bose in it.
1 - 9 of 9 Posts
