your car knocked like crazy on that last run...i say throw in the towel, you have rod knock my friend
things to check, compression and leakdown....but
nothing can be wrong with the compression or leakdown and you can still have rod knock, so an audiable test is key..
if you have rod knock or any other debi say from pistons in the engine, the engine will need a complete tear down for inspection and CLEANING(to remove all metal that circulated in the oil system
a cheap way to check this is to pull of the vtec solenoid and check for metal shavings in the filter, another way is to pull off the vtc oil strainer on the front of the head and check its filter, if there is metal in those filters, game over
