1 - 2 of 2 Posts
Low 'n slow.
Alright buying a new set of rims cause im tired of looking at the stock ones, http://www.discounttiredirect.com/direct/findWheelDetail.do?bp=5-100&yr=2002&pc=45290&counter=2&wd=17&rw=7&vid=007057 , and knowing absolutely nothing about rims, what else do i need to buy for these to make them fit, tires obviously, but will i need any spacers or anything like that? Also i drive a 5speed rsx so the rim size is 16in. Oh and it comes with a tire package as you can see if you find tire options on the page which ones would be best?
You won't need spacers, but you won't be flush either. They'll probably be a little sunken in if it's 17x7 +40. I have Work Emo's with similar specs but +42 offset and mine are slightly sunken in. Five mm spacers would definitely help if you don't mind the additional vibrations they may cause. Anything thicker would require extended studs.
1 - 2 of 2 Posts
