1 - 20 of 1462 Posts
EJ25 FTW
EWG is the answer..lol
how dangerous is 20psi anyway?
would running the stock catback make boost creep better or worse? I would think worse because there is less room for the wastegate exhaust to get out.
on the other hand if you aren't getting as much exhaust flow maybe it won't creep up as fast to start with
Bottlenecking the system might help, but isn't he running the stock catback?
EJ25 FTW
Discussion Starter #5
show us the front mount oil cooler :jelly:
my little vf46 shouldn't be seeing over 18 often lol. The guy said that based on all the ecu parameters set and over multiple logs I've sent to him that it is still overboosting, it had to be something mechanical. It confirmed what I had thought all along because even when the car was bone stock, the car was spiking over 16 psi and the ecu was dialing it back to acceptable levels and then building boost again.
Doesn't Give A F*ck
:drool:
EJ25 FTW
Discussion Starter #15
1001 miles in less than 2 weeks :awwyea:
