1 - 20 of 147 Posts
Supercharged Crew #37
< How it Began as N/A
< Cold Air intake to Throttle Body
< CAI Elbow to TB removed
< CAI Piping covered to prevent coolant spilling into it
< Undo all hoses attached to intake manifold
< Bleed Fuel Rail
< Fuel Rail removed with new RC 750cc injectors installed
< Front Bumper removed
< Bracket holding the Intake Manifold from underneath
< Intake Manifold removed, Hondata IMG shown
Discussion Starter · #2 ·
< Removing Power Steering Pulley (*Ghetto Style)
< 2nd picture of Ghetto Rigging a Pulley remover
< P/S Nut removed
< P/S pulley removed
< Removing my mugen passenger motor mount
< bird eye view of motor mount
< Motor Mount removed
< Trimming the headlights for space
< Trimming completed
< Auto tensioner Removed
< How it looks at this point
< Front shot
< Out comes the alternator
< alternator removed
< Removing the bolts from A/C compressor to fit spacers
< without upper spacer installed
< with upper spacer installed
< Without lower spacer
< With lower spacer installed
< Side view
< alternator spacers installed
< adjusted ground wire on starter under plastic cover
< alternator re-installed
< blower + manifold assembly installed
< Tensioner bracket installed
< motor mount re-installed
< Replacement power pulley installed
< Belt routing
< Belt route around manual Tensioner
Discussion Starter · #5 · (Edited)
< Harness clip holders needs cutting
< blower manifold support mount
< Arm attached to support mount and engine
< Arm installed
< New NGK Iridium Spark plugs
< New injector clips installed
< old clips snipped off, new clips soldered
< MSD 3 map bar sensor w/ Piggy back harness
< Zip-tied to frame
< Finished project, ended up boosted!!! Note the hose that connects from the nipple by the throttle body to the nipple behind the fuel rail is incorrect, this hose should connect from the nipple by the TB to the bypass valve. My bypass was broken, so that was my temp. solution to avoid vaccum leak)
^Thanks, I was hoping to find something like this when I was installing mine... so I decided to do one so it will help others out.
I hope this will help other DIYers, feel free to ask any questions if you have any as I still have the installing procedure pretty clear in my head!
Awesome DIY my friend. I have been debating weather to go SC or TC. I think I might go the SC route due to my vehicle being brand spanking new. Quick question, If I buy the JRSC for my 2006, will I need anything else other than upgrading injectors? would 550cc /min be good. Or should I just get 750cc /min injectors? Also, did you get the SC from supercharger.com Thanks in advance. And if you don't mind, i'd like to ask a lot more questions. PM possibly?
no longer blown ;(
what is your power goal or more specifically what psi do you plan on running. so as not to muck up this thread you can pm me and i will help you figure out what you need.
RIP 2/4/2009
Very nice!! :thumbsup: :thumbsup:
Makes me so glad I don't have A/C in the way so I can just take the radiator off to get easy access to the front of the engine!!
ride height Nazi
great post man.....thanks.;)
doesn't even have an RSX
This reminds me of how much a pita I thought it was to install mine. This was largely due to the fact that someone (not me) forgot to connect the alternator plug and I was completely f'ing up the belt routing.
GF in the avy
this is great. it will come in handy.
1 - 20 of 147 Posts
