1 - 20 of 26 Posts
just put tein s techs on my 05 type s...
the driver side is about half inch to a inch lower then my passenger side... front & back... any ideas?
GT30R > Traction
how long have they been on, springs take time to settle.
GT30R > Traction
also what year springs did you get for your 05? 02 to 04 don't work on 05-06
i put 02-04 struts & springs on my 05... they are used from a friend...
i was told if i change the whole struts & springs it will work wich it did fit and it drive great.... just passenger side is a little higher then the driver side
GT30R > Traction
yeah if you swap out the struts and spings your fine, make sure they are seeded correctly and that your tire pressure is the same on both sides.
GT30R > Traction
also ride hight is measured from the middle of the wheel to the fender edge.
tire pressure is fine... checked that... the springs shoudl be seated fine.... passenger side is about a half inch heigher in front then driver side
and the passenger side rear is like 1 inch heigher then the rear in the driver side
Pancakes
This may sounds dumb, but are you on totally level ground? Also, is there anything heavy on one side? i.e. Sub-box, the old springs, a great big fat person in the seat? Also, maybe you got one of the front and rear springs reversed? Beyond that, I have no freakin' clue.
Discussion Starter · #9 ·
springs are on rite... front springs are huge and rear are small....
tried the sub box idea didnt work... also the front is heigher on the passenger side as well
im at a loss here... its a noticeable difference though...
Pancakes
Sounds like you're gonna have to add some ballast to the passenger side. Maybe since the springs were used they could be worn out on one side. Like maybe whoever had them first had a bunch of weight on one side of the car.
Discussion Starter · #11 ·
no idea lol.... but i'd have to put like 300 lbs on the passenger side just to get it to level out thats REDICULOUS
and thats only in the rear... wtf am i supposed 2 do bout tha front?
GT30R > Traction
something’s not right, if I was you I would take them off and disassemble then and then reinstall... if you have the time and know how.
Discussion Starter · #13 ·
i allready did that... its wierd the car rides fine? could it be the alignment?
i havent got it aligned yet... was gonna do that tommorow
but today i installed and took them off dissasembled and reinstalled them 2 times
HONDA PACT
i had the exact same problem. i just said fuck it and maybe ill just settle more. week went by and not much difference. its been over a month now and its about 1/4" higher on my passenger side, but you really cant notice it unless you try to measure it with your fingers. i hardly drive my car to places with a passenger, i usually carpool if i ever go out so maybe thats why its taking longer to setting in on the other side.
You're from the states right?
Find a fat gf.
Otherwise I seriously have no solution for this. I wonder why its like that.. Maybe your friend bought the fake Tein springs.
GT30R > Traction
Find a fat gf.
low blow Mark:rotfl::rotfl:
Discussion Starter · #19 ·
getting it aligned 2day... dunno maybe that will help lol...
even on flat ground... pass side rear is like 1 finger higher and the pass front is but half finger hiegher then driver side
1 - 20 of 26 Posts
