1 - 10 of 10 Posts
I have an 05 type S. I have tein S springs and koni yellows. the rear is sitting way lower than they are suppose to. the rear tires are under the fender tucking. what can be causing the issue?
the car went from OEM springs and shocks to the tein springs with the koni shocks
Can bad bushings be the cause? I read that blown shocks wouldnt lower the car, that the springs is what the car sits on.
any ideas? ill post a pic later today
thanks,
Roger
allmotor whore!
shock and spring was made for a rsx ?
Its the first time that a see a car that low with tein s spring.
Discussion Starter #7
After checking everything under the car nothing seems to be loose or bent
Can the springs wear out and loose their stiffness causing them to get lower,?
Im brainstorming here as not sure what might be causing the issue
Any ideas?
Discussion Starter #9
Wow didnt even know they made fake tein springs, im going to check them tomorrow
Thanks:thumbsup::thumbsup:
Discussion Starter #10
I checked and springs were authentic Teins, after checking more with my mechanic, he mentioned if the springs were preloaded when they were installed, and apparently they were not.
after doing that, it did raise the car.
1 - 10 of 10 Posts
