Any input at all?
Okay but 165 doesn't seem TOO low. The step by step guide I saw online, the guy got all 170's. So you aren't far behind. And you say your numbers were low at 165. Look at mine....all in the 120's....so what does that say about my numbers? I can't remember if I did the compression test with the throttle pressed down or not but either way those are extremely low numbers. But my car seems to be running just fine. So that makes me wonder if it is in fact something wrong with my compression....or if I just fucked up while doing the test.i had low numbers on my 05 type S as well, 165 on all 4..
but somebody here told me its because i did my test with my throttle closed, and that doing a compression test with throttle closed yields lower numbers.
everywhere else i read people are getting like 200psi on all 4...
thats quite a difference. i have also misshifted a couple times.
now, if i understand this correctly, the over rev occured when in neutral. i have done this, but my tach doesnt go that high (9000). nomatter what, if you mash the gas in neutral, our ecu WILL NOT allow it to rev that high. if your tach says 9000, it is very innacurate, because the only way to rev it that high is 1) kpro 2)mechanical over rev (hitting a lower gear when upshifting). i once hit wat seemed to be 10,000 rpm according to my tach, but experts on here tell me that the tach was flat wrong and i only hit 9000 at most (i hit 2nd iunstead of 4th at 8000). i did catch it fast, but it was MECHANICAL. what your saying is not mechanical. the rev limiter will stop it from hitting that if it is throttle induced. oh and i have had no problems since then.The only reason I am a little concerned is because I have overrevved a few times. Never mis-shifted but times when I have tried going into gear and it's popped out and I floored the gas and it took the rpm needle all the way to 9,000.
Well the only time I have ever overrevved has been when I have tried shifting to another gear and it has popped out and landed in neutral right as I mash the gas down to the floor. I have never mis-shifted (in 3rd gear, trying to go into 4th but instead going into 2nd). When I said I revved to 9,000rpms, I didn't know for sure, I just mean that everytime I have ever overrevved in neutral (probably about 4 or 5 times since owning the car for almost a year and a half) I have never seen the tach long enough to tell how high the rpm's got, but just that it seemed to go that high.now, if i understand this correctly, the over rev occured when in neutral. i have done this, but my tach doesnt go that high (9000). nomatter what, if you mash the gas in neutral, our ecu WILL NOT allow it to rev that high. if your tach says 9000, it is very innacurate, because the only way to rev it that high is 1) kpro 2)mechanical over rev (hitting a lower gear when upshifting). i once hit wat seemed to be 10,000 rpm according to my tach, but experts on here tell me that the tach was flat wrong and i only hit 9000 at most (i hit 2nd iunstead of 4th at 8000). i did catch it fast, but it was MECHANICAL. what your saying is not mechanical. the rev limiter will stop it from hitting that if it is throttle induced. oh and i have had no problems since then.
IF IT WASNT MECHANICAL, THEN I SERIOUSLY DOUBT YOU HIT 9000. plus our valvetrain can take 8800 stock (not for a long time though). If the computer reads overrev to the dealership, i would push the issue that you did not over rev it echanically, but instead it popped out of gear and revved out because your fot was on the gas. if that indead happened, there is an issue with your ecu's rev limiter (highly doubtful)
Yea I know it's not hard to do which is why I was thinking I might have done something wrong to get numbers that low. I would like to do a compression test again but need to get some time first. How tight should I tighten the spark plugs when I put them back in? I don't have a torque wrench and it's hard to tell how tight you are making them when they are deep down in the cylinderMissing 4th gear and hitting 2nd gear at 8k rpms = a misshift at 11k rpms
PackerManDan, do another compression test, floor the throttle and crank 5 times
record and post back, a compression test is very easy to do, just take out all of your spark plugs and screw in the hose to one cylinder at a time, crank the motor, get out, record PSI, relieve pressure, unscrew and repeat for cyl 2, 3, and 4..
I can almost be sure it is your compression tester. That is why you are getting low numbers. Try doing a compression test on another rsx with the same compression tester and I bet you will get simular numbers. I used a cheap compression tester once on my car and got 120 psi in all cylinders and then I used a MAC compression tester and got 210 in all cylinders. As long as the numbers are simular in all four cylinders you should be good. I doubt you lost the same amount of compression in all four cylinders.Yea I know it's not hard to do which is why I was thinking I might have done something wrong to get numbers that low. I would like to do a compression test again but need to get some time first. How tight should I tighten the spark plugs when I put them back in? I don't have a torque wrench and it's hard to tell how tight you are making them when they are deep down in the cylinder
