1 - 10 of 10 Posts
Super Moderator
I've searched and searched all over this website thinking I saw this here. But then re-found it again on k20a.org. Since I can't find this here I thought I would share my findings. If this is a repost I'm sorry please delete it, your searching is better than mine. Credit for this goes to the TS FROTH on k20a.org
This is a comparison of every major sensor located on the Cylinder Head/Engine block of a K24/20. However, this is not just for the electrical sensors but anything that is used to actuate a particular engine function. I got the idea after listing the VTC sensor in a thread on here, All comparisons are done using the following vehicle models. RSX, RSX-S, TSX, Accord, CRV, Civic, Element. I am not including the DC5-R because they share so many commonalities with the RSX-S it would be pointless. The most common used parts will be BOLDED as well as any of those common parts that match eachother. All emissions sensors are excluded as they are mostly particular to the specific vehicle throttle body.
Sensors/Valve Assemblys:
-Knock Sensor
Accord 04-07 Knock Sensor P/N: - 30530-PPL-A01
Civic 03-05 Knock Sensor P/N: - 30530-PPL-A01
CRV 03-07 Knock Sensor P/N: - 30530-PPL-A01
Element 03-07 Knock Sensor P/n: - 30530-PPL-A01
TSX 04-07 Knock Sensor P/N: - 30530-PPL-A01
RSX 02-06 Knock Sensor P/N: - 30530-PPL-A01
RSX-S 02-06 Knock Sensor P/N: - 30530-PRB-A01
Civic Si 06-07 Knock Sensor P/N: - 30530-PRC-003
-Crank Position Sensor
Accord 03-07 Crank Position Sensor P/N: - 37500-RAA-A01
Element 03-07 Crank Position Sensor P/N: - 37500-RAA-A01
TSX 04-07 Crank Position Sensor P/N: - 37500-RAA-A01
CRV 02-07 Crank Position Sensor P/N: - 37500-PNB-003
Civic 03-07 Crank Position Sensor P/N: - 37500-PNB-003
RSX-S 02-06 Crank Position Sensor P/N: - 37500-PNB-003
RSX 02-06 Crank Position Sensor P/N: - 37500-PNB-003
Civic Si 06-07 Crank Position Sensor P/N: - 37500-PNB-003
-Camshaft TDC sensor
Civic 02-07 Camshaft TDC Sensor P/N: - 37510-PNB-003
RSX 02-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
RSX-S 02-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
CRV 03-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
CRV 07 ONLY Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
Accord 03-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
Element 03-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
TSX 04-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
Civic Si 06-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
-MAP Sensor
Accord 03-04 MAP Sensor P/N: - 37830-PGK-A01
CRV 02-04 MAP Sensor P/N: - 37830-PGK-A01
Civic 01-05 MAP Sensor P/N: - 37830-PGK-A01
RSX 02-04 MAP Sensor P/N: - 37830-PGK-A01
RSX-S 02-04 MAP Sensor P/N: - 37830-PGK-A01
TSX 04-07 MAP Sensor P/N: - 37830-PGK-A01
Civic Si 06-07 MAP Sensor P/N: - 37830-PNC-003
-Water Temp. Sensor
Accord 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
CRV 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
Civic 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
Element 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
RSX 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
RSX-S 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
TSX 04-07 Water Temp. Sensor P/N: - 37870-PNA-003
Civic Si 06-07 Water Temp. Sensor P/N: - 37870-PNA-003
-VTC Spool valve assembly
Accord 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
CRV 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
Civic 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
Element 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
RSX 02-06 VTC Spool Assembly P/N: - 15810-RAA-A01
RSX-S 02-06 VTC Spool Assembly P/N: - 15810-PRB-A01
TSX 04-05 VTC Spool Assembly P/N: - 15810-PRB-A01
Civic Si 06-07 VTC Spool Assembly P/N: - 15810-PRB-A03
-VTC Oil Control Valve Assembly
Accord 03-07 VTC Oil Control Assembly P/N: - 15830-RAA-A01
Element 03-07 VTC Oil Control Assembly P/N: - 15830-RAA-A01
CRV 03-05 VTC Oil Control Assembly P/N: - 15830-PNC-003
Civic 03-05 VTC Oil Control Assembly P/N: - 15830-PNC-003
RSX-S 02-04 VTC Oil Control Assembly P/N: - 15830-PNC-003
RSX 02-04 VTC Oil Control Assembly P/N: - 15830-PNC-003
TSX 04-07 VTC Oil Control Assembly P/N: - 15830-RBB-003 (same as 05-06 RSX-S)
Civic Si 06-07 VTC Oil Control Assembly P/N: - 15830-RBB-003
-Timing Chain Tensioner
02-07 CRV - 14510-PNA-003 (K24A1 and K24Z1)
03-05 Civic Si - 14510-PNA-003 (K20A3)
03-07 Accord - 14510-PNA-003 (K24A4 and K24A8)
02-06 RSX Base - 14510-PNA-003 (K20A3)
03-07 Element - 14510-RAA-A01 (K24A4)
02-06 RSX-S - 14510-PRB-A01 (K20A2 and K20Z1)
04-07 TSX - 14510-PRB-A01 (K24A2)
06-07 Civic Si - 14510-PRB-A01 (K20Z3)
07 Acura RDX - 14510-RWC-A01 (K23A1, Turbo)
For anyone doing a swap I hope this helps you because it has definitely helped me.
Si vis pacem, para bellum
Well, I know you are doing a K24a swap like me...which sensors did you take from your RSX and put on your TSX engine?
Didnt want to make a new thread but i broke my knock sensor while taking off the starter... replaced it with a b-series ks... its a must that i must change back to the k20 ks? Thanks
Im swapping from my stock k20a2 in my 03 rsx-s to a k24a1/k20z3. I noticed that the knock sensor part number for the crv and base model rsx is the same, but the rsx-s is different. Also, the guy I got the motor from used a k-pro'd a3 ecu.
Can I use this knock sensor with my k-pro'd a2 ecu or should I swap the sensor? I'll be temporarily using his k-pro map to run my engine.
very helpful thanks
1 - 10 of 10 Posts
