1 - 20 of 1021 Posts
Engineering
hey guys, well frankly i've become tired of those threads asking "do i have the correct harness?" so i thought i'd help out by creating a thread that encompasses all of the different varieties of harnesses out there. this will have to be a combined effort as i will need pictures of your harnesses (for those of you that have working harnesses) and also the name of the ebay seller. as of now i only have pictures of Trendgear's harness. so if any of you have any pictures of your harnesses, post them up. hopefully this will end all of those threads.
LINK TO EBAY HARNESS PROBLEM FIX:
http://forums.clubrsx.com/showthread.php?t=584514
Big thanks to iShift_6 and madru17 for pics
TRENDGEAR'S HARNESS
this is what trendgear's harness looks like:
this is how trendgear's harness is plugged in:
in order for this harness to work, the white plug around the red wire must be broken off. use tape or heat shrink tubing to secure the plugless red wire to the hanging brown connector. the green plug connects to the switch.
here is their switch:
if you would like to use the OEM switch with this harness, here is my DIY:
http://forums.clubrsx.com/showthread.php?t=469745
MOTORBLVD'S HARNESS
ATOMIC STREET'S HARNESS
this is what atomicstreet's harness looks like:
now take a look at this pic again:
these are the connectors that go inside the fuse box:
for the 2 on the left, listen carefully. refer back to the pic of the fuse box. do you see where the arrow starts? there will be a green plug there. remove that, and then follow the directions on my picture. you will plug the white female part into the fuse box, and connect the white male part to the green plug.
this is the plug that will connect to the hanging brown connector:
and this is the plug for their switch:
this is their switch:
the OEM switch will plug and play with this harness
Engineering
Discussion Starter · #3 · (Edited)
OTHER MOTORBLVD HARNESS
this is the first time i've seen a harness like this, it is a cross between trendgear's harness and atomicstreet's harness, so here is a pic of the harness:
like the atomic street harness, the 4 plugs here go into the fuse box and the brown connector. same exact thing:
here is the green plug that connects to the switch:
and here is the switch, the back is similar to the trendgear, but the face is different:
you will have to follow my DIY again if you want to use the OEM switch.
COMPARISON OF SWITCHES
starting from the left:
OEM, Atomic street, Trendgear
motorblvd switch
Reactions: jinusean and JCL
Engineering
bump, help me help you!
JDM Ho Fo SHoooo
Engineering
haha thanks, everyone i need pics of your harness and the name of the ebay seller.
Engineering
Discussion Starter · #8 ·
thanks, i'm trying to get people to do that...
Sitting in traffic.
I've got pictures of an Atomic Steet one, and a few of a Trendgear if you want more. All are uninstalled. I've also got comparison pictures of all the switches. Let me know what you want, of if I should just post them.
Engineering
Discussion Starter · #10 ·
thanks, i just need pics of the atomic street interior harness, and pics of the switches would be nice too. i PMed you my email, send pics and i'll put them on here.
Reactions: 808DC5R
Engineering
Discussion Starter · #13 ·
thanks Doug for your help. one step closer!
Engineering
Discussion Starter · #15 ·
bump for updates!
Engineering
Discussion Starter · #18 ·
thanks todd, bump bump bump it up!
Reactions: Xqzrt
REV HIGH DRIVE HAPPY
wait im a bit confused is there information on motorblvds harness? i just bought it and its sitting in my room im gonna install it tomm
Reactions: Dawrenn
Engineering
Discussion Starter · #20 ·
yes i have the info on how to install. i just need pics to go along with it. i will PM you the instructions, can you take photos of the fog harness, switch, and all connectors for me?
