1 - 9 of 9 Posts
yesterday after fast driving on the turnpike and hitting the rev limiter a couple times, AND having to fill up my tank at a BP instead of chevron[both 93 octane though], i noticed i had a cel this morning...
when i start the car[05 type S] the "maint required" light blinks 10 times.
the car is running fine..i think. idle is good, power is still good, etc..
i looked at the cel codes but is there a way to tell what error you have w/o hooking up to a computer? anybody have this problem befor? i was thinking mabey if i reset the ecu it will go away...:dontknow:
THE CHECK ENGINE LIGHT IS NOT THE SAME AS a MAINTENANCE REQUIRED LIGHT
i was thinking about that, was does the "maint req" light indicate then? like intervals of service needed, like its automatic at certain points?
Discussion Starter · #9 ·
hold the button on the guage cluster (odometer button) then turn the ignition on and continue holding it for 10 seconds or so until the light goes off. it is to remind you that you scheduled maintainence is close to being due
thanks im gonna do it right now, nice avatar too btw! :D
1 - 9 of 9 Posts
