Inch-pound torque wrench. They are quite common.
:iamwiths:Inch-pound torque wrench. They are quite common.
How did you do this without throwing off the adjustment? The threaded rod seems to turn every time, so I stick to an open or box end, and a small amount of blue threadlocker.When I did my cam install, all I torqued down with a torque wrench were the cam caps, valve lash adjusters, cam gears, and cam sensor wheels.
If it wants to move, I snug the nut a little with an open wrench before torquing. Then it doesn't usually move. If you get a stubborn one, just back off the screw a little before torquing and double check after torquing. I fly through them so fast now that when I run into one of those, I just open it a bit and try again and it usually takes.How did you do this without throwing off the adjustment? The threaded rod seems to turn every time, so I stick to an open or box end, and a small amount of blue threadlocker.
