1 - 4 of 4 Posts
so the stickker in my rsx door recommended my tires pressure front to be 33 psi...rear is 31 psi...one of mine friend told me that i should lower to 27 psi front.. and rear to 25...is that ok...cause my car is bouncy....my current tires pressure is 31 psi frount ...30 psi rear..
use the stock pressures. doesn't matter what tires you have on.
if u lower tire pressure, you'll have extra wear on side tread of your tires while the center tread is less worn.
if u increase tire pressure, you'll have extra wear on center tread while the side trade is less worn.
the only times you should be messing with tire pressures is when you're racing. street driving, you should be doing what's on the door.
1 - 4 of 4 Posts
